Discussion Groups
Simulation CFD
fathur.rozi
Re: Analysis has stopped because the Solver has exited Unexpectedly
11-04-2013 01:38 AM in reply to: allous5
Dear Jon,
I apologize to bother you again, I still got same problem after uninstall/reinstall CFD, for info, I use windows 8.0, the software is located in my pc as administrator, I run the model from my local C drive.
Thank you
Kind Regards,
Fathur
Please use plain text.
Product Support
wildej
11-04-2013 01:41 AM in reply to: fathur.rozi
Hi Fathur,
Sorry to hear you are having problems. It might be worth taking a look here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18552021&linkID=18154757
Are you still running CFD 2013? If so, then Windows 8 is not supported, which is a likelt explanation.
If you are running CFD 2014, it should be OK.
Best regards,
Jon
Jon Wilde
fathur.rozi
11-04-2013 01:47 AM in reply to: fathur.rozi
Hi Jon,
I use Autodesk_Simulation_CFD_2014_Multilingual_Win_64bit_dlm
thx,
fathur
Product Support
wildej
11-04-2013 01:54 AM in reply to: fathur.rozi
Have you tested a really simple model to verify that the model setup is not the issue?
Jon
Jon Wilde
fathur.rozi
11-04-2013 02:10 AM in reply to: wildej
Yes, I already tried with simple pipe model
Fathur
Product Support
wildej
11-05-2013 01:39 AM in reply to: fathur.rozi
Hi Fathur,
Just to be clear - are you seeing an error or just finding that the model remains queued?
Did you clear out the server manager?
Kind regards,
Jon
Jon Wilde
Valued Contributor
JohnTomasik6493
11-05-2013 12:27 PM in reply to: wildej
I have the same issue.  See attached JPEG.  I'm running one of the tutorials, and about 160 steps in, I get the attached message.  Thinking I have write permission issues on my C:/ drive, I copied the entire Simulation CFD 2014 directory to my slave drive (D:/ - which is where I keep all of my data files local).  I still get the same error.
Product Support
wildej
11-06-2013 01:33 AM in reply to: JohnTomasik6493
Hi John,
I suggest you leave the installation folder alone - apart from one thing - could you right click it and check the security settings. Check that that 'user' account has full access.
Jon
Jon Wilde
fathur.rozi
11-06-2013 10:53 PM in reply to: fathur.rozi
Dear Jon,
Excuse me, continue to this discuss, my server manager status is Ok, even my colleague who run CFD with link to license in my computer also running well,
I attached the step before stuck on solving, it seem like not connected to the license.
in the error message there is @127.0.0.1 I don't know, this is not may IP address
Thank you and Best Regards
Fathur
fathur.rozi
11-06-2013 11:41 PM in reply to: fathur.rozi
Dear Jon,
I am sorry forgot the attachment
Regards
fathur
