Discussion Groups
Simulation CFD
Member
Accepted Solution
Analysis has stopped because the Solver has exited Unexpectedly
563 Views, 22 Replies
10-23-2013 04:55 AM
hello there,
I have Autodesk Simulation CFD 2013 and the software is running normally. The issue arises every time I tried to generate the mesh, the following error message pops out: Error Message—Analysis has stopped because the Solver has exited Unexpectedly I have tried all options  as mentioned in the following link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17496447&linkID=18154757
such as: solving the memory problems and increasing the
required RAM (MaxRadMatrixSize 6GB) coarsen the mesh simplifying the geometry and BCs as well. Even with a simple problem such as flow inside a single pipe,  the same issue happened. (take a look at the attached file)
please let me know what the problem could be and how to resolve it?
thank you very much
regards,
EJ
Please use plain text.
Product Support
wildej
Re: Analysis has stopped because the Solver has exited Unexpectedly
10-23-2013 05:48 AM in reply to: allous5
Hi EJ,
Can you confirm that you are running this from a local harddrive?
Kind regards,
Jon
Jon Wilde
Member
10-23-2013 05:58 AM in reply to: wildej
Dear John,
no, I'm running the software on a sharing network.
the main software is located on the administrator pc (on my boss pc) therefore, we are using the software on a shared network.
I tested the software on his pc, and it running perfectly.
what do you think I should do in this case??
thanks for your response.
EJ
Product Support
wildej
10-23-2013 06:00 AM in reply to: allous5
By using on a shared network do you mean you have it installed locally but with the licence networked?
If that is the case, I suggest you try running the model from a local file.
Kind regards,
Jon
Jon Wilde
Member
10-23-2013 06:06 AM in reply to: wildej
Yes, correct
I meant that the software is installed locally but with the license networked.
ok so then how to run the model from a local file??
can you explain please in more details
EJ
Product Support
wildej
10-23-2013 06:10 AM in reply to: allous5
Hi EJ,
It is fine to use a network licence.
I mean that the project you open must be on your C drive - the cfdst or CAD you launch from must be held here. This is the likely cause.
Does that make sense?
Jon
Jon Wilde
Member
10-23-2013 06:22 AM in reply to: wildej
Great
I transferred my Autodesk project and CAD model to the main C drive and now it's working and the mesh is generated :smileyhappy:
I really appreciate your help
thanks
EJ
Product Support
wildej
10-23-2013 06:23 AM in reply to: allous5
Hi EJ,
Not a problem, pleased to hear it works.
Jon
Jon Wilde
11-03-2013 07:05 PM in reply to: allous5
The same problem may happen to me, the process stuck when solving, I try to stop the process and I try with a new file, also stops with quequed message.
please help me
thank you verry much
Product Support
wildej
11-03-2013 11:35 PM in reply to: allous5
It sounds like your first problem is that you have a model stuck in the queue. With CFD closed, open up the SimCFDserver (right click and run as admin) and then Stop/Uninstall/Reinstall the server using the available buttons. That should give you a fresh slate to start running from - the model that shows as queued might not run though, you may need to start over from the _support.CFZ that would have been created when you pressed 'Solve'
Kind regards,
Jon
Jon Wilde
