Discussion Groups
Simulation CFD
mingyar
Accepted Solution
Advice on flame simulation
159 Views, 2 Replies
06-10-2013 11:21 AM
Hello, can you give me some advice on how to simulate a flame inside a steel tube?
I try to set it as butane but then I have an error message that I have two fluids touching each other (the butane and the air around the tube )
Please use plain text.
Product Support
Royce_adsk
Re: Advice on flame simulation
06-10-2013 11:30 AM in reply to: mingyar
Hi Mingyar,
With Autodesk Simulation CFD you cannot model combustion effects.  With that said you can create a resistance region that is approximatly the size of your flame and apply a volumetric heat load to that resistance to include the heat released by the flame.
-Royce
Royce Abel
mingyar
06-10-2013 11:42 AM in reply to: Royce_adsk
Thanks Royce that's exactly what I need, just to simulate the heat released by the flame.
Thanks again
