CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Accurate Airflow model
10 REPLIES 10
Message 1 of 11
594 Views, 10 Replies
I have set up a model to simulate airflow through a canopied generator set.
The model is very simple with a fan pulling airflow through inlet ducts, over an engine, through a cooling core and out a 90 Degrees vertical outlet duct at the top of the canopy.
The geometry has been set up with 0 gage pressure only as a boundary condition, the fan has a fan curve from the supplier and the cooling core has an air restriction curve from the supplier.
I am looking to run an accurate model as possible but due to computational restraints, cubes represent engines etc.
The outcome I am looking for is a pressure restriction of the canopy and a volumetric flow at the outlet.
I know there is a summary report, but is there a way to set up a plane to show volumetric flow at the outlet? Or the pressure drop through the system?
Also, I know increasing meshing size will help accuracy of the model, but is there any other tips/help more experienced users can offer to better setup this model. For example, does setting a free air ratio as a resistance instead of a restriction curve better represent reality within Autodesk Simulation?
Thanks in advance
10 REPLIES 10
Message 2 of 11
Jon.Wilde
Sounds like you have the right approach, there are a few things to mention that might help:
  1. Suppress all solid parts from the mesh if you are not interested in heat transfer though them, this will save on mesh count
  2. A resistive region should be accurate with either approach, so long as whatever you assign matches reality
  3. You need a good uniform mesh on resistance regions and fans, aim for at least 4 elements through their thickness
  4. You can measure flow or pressure on planes by addingn a cut-plane and using the bulk calculator - search the help and use the Wiki if you need more detail, it explains it all well.
Message 3 of 11
in reply to: Jon.Wilde
Thanks Mr. Wilde,
Does suppressing solid parts just stop heat transfer through them? Do they not have to be meshed for the CFD program to ascertain aiflow patterns around/ past/over solid objects?
Would this mean the only meshing I would be applying would be to the fan and the cooling core?
If I am modelling a fan, is ther any rules of thumb for the modelling? Currently I am using a cylinder, with no inner fixed hub modelled. It is set to the thickness of the suppliers drawing from one side of a blade tip to the other.
I feel I will have to play about with the resistive regions,  at the moment I have a grill outlet setup as a pattern from the model which is creating alot of nodes. I think it might be better to set this as a resistive region with a free air ratio.
Thanks.
Message 4 of 11
Jon.Wilde
Not a problem 🙂
Does suppressing solid parts just stop heat transfer through them? Do they not have to be meshed for the CFD program to ascertain aiflow patterns around/ past/over solid objects? You are correct, it will just stop the heat transfer, the flow patterns around them would not be affected.
Would this mean the only meshing I would be applying would be to the fan and the cooling core? And the air, yes.
If I am modelling a fan, is ther any rules of thumb for the modelling? Currently I am using a cylinder, with no inner fixed hub modelled. It is set to the thickness of the suppliers drawing from one side of a blade tip to the other. What you have souds sensible, although it is worth including a solid part around the outer diameter to ensure that no flow can leak. also ensure it has a good uniform mesh.
I feel I will have to play about with the resistive regions,  at the moment I have a grill outlet setup as a pattern from the model which is creating alot of nodes. I think it might be better to set this as a resistive region with a free air ratio Yes, this might be worthwhile. You can set the resistance to be different in each of the x.y,z directions to try to mimic the grill pattern.
Message 5 of 11
Many thanks for the reply.
I just have a couple more questions.
1. When I am modelling the fan, is it better to have a solid cylinder in the center to represent the hub? I have set a solid exterior to stop flow leak.
2. I have set up  the geometry as a 0 Pa gage pressure. Is there any need to specify inlets as 0 Pa gage pressure as well?
Thanks in advance.
Message 6 of 11
Jon.Wilde
1. When I am modelling the fan, is it better to have a solid cylinder in the center to represent the hub? I have set a solid exterior to stop flow leak - It does not really matter althuogh you can do - suppress it from the mesh if you do.
2. I have set up  the geometry as a 0 Pa gage pressure. Is there any need to specify inlets as 0 Pa gage pressure as well - I am unsure what this means. You only want to assign a p=0 to the fluid where there is an opening and only on the boundary of the model - nothing internally
Does that make sense?
Jon
Message 7 of 11
I have been working on/off with modelling on this simulation and had been getting good ball park data with good convergence until I realised the fan had been set to zero slip factor. When I start to increase this the convergence plots look like a sinusoidal wave plot with sharp drops and peaks creating nonsensical summary data.
I have checked the model, materials, meshing and input data and all seem to be accurate for a steady state airflow simulation.
Am I missing a further check? Is it reasonable to assume a slip factor of a pusher fan to be closer to 1 when using supplier curve data?
I have also noticed this happening when I change the advection from 1 to 2.
Message 8 of 11
Jon.Wilde
We usually have the slip at about 0.7.
ADV5 is normally the best scheme for this type of model too.
Do you find that the model eventually converges? Perhaps you need more mesh or difference BC's?
Message 9 of 11
Hi John,
Thanks for replying.
I am using CFDesign 2011 which doesn't have ADV5. The meshing is as fine as can be for the fan.
The model eventually converges but the summary data does not read correctly - Please see attached screenshot. This is with the ADV set to 1 and the slip set to 1.0 (I stopped this into the run due to the convergence plot display). I have tried this with alip at 0.25, but the outcome is the same (Iterations converges around 1100).
The only boundary condition I have set is 0 Pa for the four walls and roof of the surrounding space. No other BC has been set.
Message 10 of 11
Jon.Wilde
I would certainly say that ADV2 would be best then.
This convergence plot does not suggest convergence, if you ever see anything like this, just stop the model as it is not right.
Do you have some thin parts in there too (looks like you may do), resitances maybe? If so, are you using surface or volume resistances? Is the mesh tight on these also? 3-4 elements inlet to outlet (same as the fan)?
How large is the overall domain?
Message 11 of 11
I have tried ADV2 as well. Initially it seemed to be okay then started to converge like the attachment showed. There are thin resistances simulating inlet and outlet grills. They would be about 2mm in depth. I have tried tightening mesh on these but it doesn't change the convergence plot. I can only select the type as a resistance, I don't know if it is set to surface or volume. Is there a way to check on cfdesign 2011 version? On material selection I would specify the flow in the direction it enters the model, is this correct? Same with the fan.
The overall domain is a good bit bigger than the shown model, probably about the same distances again to each wall. As I said this has been set to a zero pressure, and a material selection of air.
