Discussion Groups
Simulation CFD
Accepted Solution
8 core machine uses only 4 cores
215 Views, 4 Replies
10-16-2013 02:19 PM
Lately, I added the 2nd processor that has 4 cores resulting in total 8 cores.
But, the solver still uses only four cores. What am I missing?
Thanks.
Please use plain text.
*Expert Elite*
Dan.M
Re: 8 core machine uses only 4 cores
10-16-2013 11:12 PM in reply to: csjhun
Maybe your cores are multi threaded.
CFD only uses the physical cores.
Dan
10-17-2013 06:35 AM in reply to: csjhun
I'm 100% positive that it's not multithreading. Again, I put two (identical) physical processors (each of them has 4 cores).
I have both CFD 2013 SP1 and CFD 2014 on my machine; interestingly enough, I can run both versions at the same time, say, one uses 4 cores, and the other uses another 4 cores. Any explanations?
Product Support
Royce_adsk
10-18-2013 05:52 AM in reply to: csjhun
You will probably need to run SimCFDConfig.exe at this time for the installation to update it settings.
When you do run this program run it with right click - 'run as administrator'.
Also, delete this file before you run the configuration program: C:\Program Files\Autodesk\Simulation CFD 2014\SystemInfo2014.xml
Let us know if that fixes the issue!
Royce Abel
10-23-2013 11:16 AM in reply to: csjhun
It worked. Thanks, Royce.
