Problem1: When solving a transient simulation, it's often needed to save monitor point data for a specific variable after convergence. However, when hit save, it saves all the variables which is not useful and can be confusing. It would be helpful if Autodesk fixex this simple issue.
Problem 2: It's desirable to change the monitor point data units indepedent from the original defined unit during simulation setup. However, this capability is not provided in the current version. Again, Autodesk is encouraged to add this feature.
