Renaming Parts of geometry within the CFD UI.
I want to be able to edit the part names of any geometry within the CFD UI.
In the Design Study Bar under Scenario 1 --> Material --> Unassigned --> ‘Part Name’, I want to be able to right click the ‘Part Name’ and I want a menu item which says ‘Rename’ (much like what is seen when ‘Scenario 1’ or ‘Design 1’ are right clicked).
See attached screenshots.
Thank you,
- Abdus Khan
Software Quality Assurance Co-op
Autodesk Simulation CFD
6 Comments
I create a multi-body 2D assembly by creating 16 patches (surfaces) and renaming the patches as if they were parts all while in Inventor. When I bring the assy into CFD it renames all my surfaces 1 thru 16 (see picture). In order of preference I would like to:
1. keep the same names (ex: Lower TFE, Upper TFE, etc.).
2. have the ability to rename parts as described in Khan's idea (see above)
Regards, Dan
tfjield
This is such a basic requirement that it boggles my mind that it isn't already implemented.
Almost 4 years after this basic feature (which you find on any othet engineering software) has been requested, it still hasn't been implemented. This Idea Station is just and eyewash to make customers believe that Autodesk cares.
Related Idea to what @Anonymous mentioned: Import solid body names from Inventor multi-body Part files
asiu
The interface needs a lot of improvement to make it more productive when working with many volumes.
This is a basic feature that will help in many ways.
Almost 5 years and 24 votes...
new to this software. still nothing on this topic?
thank you!
