Improve Inventor export for certain models with patterns
For models with large patterns the Inventor export will not work or take days, so the only way to work "efficiently" is to export/import *.sat-files.
5 Comments
hartogj
Hi Marco - any example models you can share?
hartogj
Status changed to: Comments Requested
hartogj
Hey Marco - I received your email with the sample file and am seeing behavior similar to what you described. We'll take a deeper look into this. Thanks.
hartogj
Status changed to: Accepted
apolo_vanderberg
Autodesk Support
As a workaround for some of these you can now load the file directly in to CFD (not push from Inventor but Pull from CFD)
File - New and opint to the inventor geometry. On some models where I have seen similar behavior to what you describe with launching, opening direct is faster and maintains associativity vs exporting to sat
