Heat pipes are quite ubiquitous these days in electronic packaging. The short cut to model the heat pipe as a highly conductive (~50-100,000 W/mK) rod must be done very carefully as it does not take into account the heat transfer capacity based on temperature and tube diameter. If the one does not take into account these variables then the simulation will give extremely optimistic results.
It would be great if Simulation CFD had a Compact Material Model for heat pipes that would perform the necessary transfer curve for the model.
Please?
