Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Flow Vs Time plot; fot transient analysis
After solving for Transient analysis, i need to see the effect on flow (flow vs time plot). But currently such plot is not available as a direct output unlike velocity, press, temp. Same is the case for plots available at monitoring points. So for this I need to extract flow values for every iterations / time steps from either summery file or from bulk results by creating a plane. This is very tideous procedure!
NEED "FLOW VS TIME" AS A  DIRECT OUTPUT.
