In Simulation CFD 2014 Help, about Users Guide, Simulation CFD 360 Notes, User Interface, Ribbon, Ribbon Tabs, Setup Tab, Results Tab, Results > Revire, Summaru File, If the outlet temperature predicted by Autodesk Simulation CFD is 31.1 C...
I think when performing the thermal fluid analysis , when analyzing an event , especially cooling and heating , important to whether the temperature difference becomes .
If it is assumed that heating by heat transfer from the heat source surface of certain relative to the fluid of 30 ℃, there is a big difference on whether the 31 ℃ as outlet temperature you pointed out whether the 31.1 ℃.
It is calculated as 85 ℃ outlet temperature and there is an error of 10% and assuming that the outlet temperature is 80 ℃ to increase the heat input a little more , but if not great this difference as impression ?
As the evaluation method of the analysis results , when you heat transfer amount , do you evaluate the heat transfer amount than the mass flow rate and temperature difference of Entry Exit , do you evaluate the amount of heat transfer from the wall , each a part
How do you think you can allow of no case where the evaluation of ...
When you look at the comments of destination development , because as you said, that will be an emphasis on temperature , what that reasonable to evaluate than the temperature difference between the Entry Exit ?
