Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Import of SolidWorks and Pro/E aka Creo Assemblies
1 REPLY 1
schneik-adsk
1174 Views, 1 Reply
If you frequently import SolidWorks or Creo Assemblies, be sure to put the assembly in its' own folder.
We can't always find all the refrences for these assemblies and so we aggressivly grab files to ensure there are no link failures when we translate.  If you place all  the needed files in a folder this helps ensure we grab the required files when we go look for refrences. This will also ensure we don't grab more that we need.
Kevin Schneider
1 REPLY 1
AIR_123
in reply to: schneik-adsk
Hi. This solution does not work. It seems only parent assembly is uploaded (at least file size says so).
Besides Creo .asm files are shown as Solidworks. But SW has different extension (.sldasm). Please advise how to solve issue uploading Creo assembly into Fusion360 web interface, so that I can share this assembly with others. Thanks
