Shape Extraction for AutoCAD
Distinguished Contributor
obourne
Message 1 of 2 (846 Views)
Using ASCII Format Point Cloud Data
846 Views, 1 Replies
03-03-2011 09:44 AM
I have PC data in ASC format (basically it's a text file). Is there a way to translate it into a format the shap extraction tool can use?
Member
Dizabled
Message 2 of 2 (837 Views)
Re: Using ASCII Format Point Cloud Data
03-04-2011 11:34 AM in reply to: obourne
You should be able to convert your ascii file using the Kubit program. It will convert it to the *.pcg format used by AutoCAD. There, with the point cloud attached to your drawing, you will be able to use the shape extraction tool.
You are not logged in.
Announcements
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Need installation help?
Ask the Community
