• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Shape Extraction for AutoCAD
    cad
    New Member
    cad
    Re: Point Coud Feature Extraction for Autodesk Revit Now Available
    01-25-2012 10:12 PM in reply to: scott.sheppard
    Same Error and Problem as explained before.
    As an Attachment the Errormessage.
    Please use plain text.
    Board Manager
    01-26-2012 07:27 AM in reply to: scott.sheppard
    User Aaron Maller and I have a theory: The technology preview does not work with installations of Revit that were done via deployments (instead of standalone) or as part of a suite. The result of how Revit was installed has an effect on the content of the user's Revit.ini file. The theory is that the Point Cloud Feature Extraction technology preview is not finding something it is expecting in the ini file. The team is investigating the issue.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    New Member
    Alberici3206
    01-26-2012 07:55 AM in reply to: Alberici3206
    I completely removed Feature Extraction, did a bunch of .net updates, download the zip file again, right clicked the zip file and unblocked it, reinstalled feature extraction and it works!
    New Member
    jaykroyd
    01-26-2012 02:42 PM in reply to: Alberici3206
    What web updates did you do.  I have tried reinstalling after unblocking the .zip file and am still getting the same error.
    New Member
    MJIMMYM
    01-26-2012 09:16 PM in reply to: Alberici3206
    if you got this error, please try install vs2010 Redistributable p[ackage
    http://www.microsoft.com/download/en/search.aspx?q=vs%202010%20%20Redistributable%20
    Member
    01-27-2012 02:25 AM in reply to: MJIMMYM
    I can confirm that this has solved the problem, at least here.
    1.Unblock at zip
    2. The mentioned vs2010 redistr.
    New Member
    jaykroyd
    01-27-2012 06:23 AM in reply to: MJIMMYM
    That worked, thank you.
    Board Manager
    01-27-2012 09:40 AM in reply to: jaykroyd
    Sicne the error message is .NET related, the Visual Studio run-time environment update may be the key! Nice work pointing that out.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Board Manager
    Re: Point Cloud Feature Extraction for Autodesk Revit Now Available
    01-30-2012 11:10 AM in reply to: ExistingConditions
    The team has provided me with a new installer that fixes the .NET problems users are having. It is available for download:
    http://www.autodesk.com/revit_pointcloud
    You should uninstall the old and install this new build.
    Scott Sheppard
    Program Manager
    Autodesk Labs
