Shape Extraction for AutoCAD
Active Member
TSymanneck
Message 1 of 9 (822 Views)
Installation Shape Extraction
822 Views, 8 Replies
10-19-2010 01:25 PM
Hi Scott,
I have a problem with installation on C3D 2011, with Update 1 on W7 64bit (German).
In the screenshot you can see the message: "Installer was interrupted".
I repeat the download, if the ZIP are damaged, but it is the same result.
Have you any idea?
Best regards
Thomas
Board Manager
scott.sheppard
Message 2 of 9 (805 Views)
Re: Installation Shape Extraction
10-26-2010 04:06 PM in reply to: TSymanneck
Out of the box, only English is supported. To see how to manually load the SHape Extraction Tool:
http://labs.blogs.com/its_alive_in_the_lab/2010/07/shape-extraction-for-autocad-hip-tip-working-with...
This blog article should help.
Scott Sheppard
Program Manager
Autodesk Labs
Valued Contributor
kgrover
Message 3 of 9 (738 Views)
11-17-2010 01:29 PM in reply to: scott.sheppard
I am having the same issues since I upgraded my machine to win7 64-bit, and I can't run the install since I get the same message as above.
I read your post to manually load the tools, but I can't even get the files from the installation since the .msi installer won't even run. Are the individual files available for download at all??
Kevin
Board Manager
scott.sheppard
Message 4 of 9 (732 Views)
11-18-2010 07:02 AM in reply to: kgrover
I zipped up what was on my Windows 7 64-bit machine. These were in the AutoCAD 2011 directory.
https://projectpoint.buzzsaw.com/ConstructionManagement/Labs/ShapeExtraction/ShapeExtractionApp.zip?...
Scott Sheppard
Program Manager
Autodesk Labs
Valued Contributor
kgrover
Message 5 of 9 (729 Views)
11-18-2010 07:53 AM in reply to: scott.sheppard
Hi Scott,
Thanks for these, but the only other item missing is the cuix.
Kevin
Board Manager
scott.sheppard
Message 6 of 9 (722 Views)
11-19-2010 07:16 AM in reply to: kgrover
New Member
padrecavada
Message 7 of 9 (698 Views)
11-24-2010 01:31 AM in reply to: scott.sheppard
i try to install in a student version of autocad 2011 and i have the same problem ..... i cant install.
help please
Valued Contributor
kgrover
Message 8 of 9 (686 Views)
11-24-2010 05:21 AM in reply to: TSymanneck
I am still having issues as well. I tried to even load everything manually as the other post mentionned, but the dll won't load using netload, and the last link that Scott placed for the cuix didn't contain the one I beleive is needed.
I didn't get a chance to post my response right when I tried it, but I am not sure if there is anything else I can do to install it.
Kevin
Board Manager
scott.sheppard
Message 9 of 9 (677 Views)
11-24-2010 08:40 AM in reply to: padrecavada
I have logged a defect to make our installer recognize the student version. We can consider that in a future release - after AU and the holidays.
Scott Sheppard
Program Manager
Autodesk Labs
You are not logged in.
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Ask the Community
