• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Shape Extraction for AutoCAD
    ExistingConditions
    Accepted Solution
    Installation Problem
    309 Views, 6 Replies
    02-15-2011 06:17 AM
    I am trying to install the new shape extraction plug-in and it tells me there is another ad-in installed that needs to be uninstalled to continue.  It asks to unistall and I say yes.  The installer then says there is a problem with this Windows Installer package.  A program run as part of the setup did not finish as expected.  Contact your support personnel or package vendor.  Any ideas?
    Nick
    Please use plain text.
    Employee
    Re: Installation Problem
    02-15-2011 08:37 AM in reply to: ExistingConditions
    NIck,
    Could it be you did not uninstall the previous version of the Shape ExtractionTechnology Preview before installing the new version?
    Best Regards,
    Shaan
    Shaan Hurley
    Technologist for the Office of the CTO
    Autodesk, Inc.
    http://autodesk.blogs.com/between_the_lines/
    @ShaanHurley on Twitter
    ExistingConditions
    02-15-2011 08:43 AM in reply to: shaan.hurley
    The webpage said to install it right over the previous version, but I have since tried to uninstall the previous version and the windows installer comes up and just disapears and the shape extractor stays listed under my programs.
    Employee
    02-16-2011 07:43 AM in reply to: ExistingConditions
    What page address has this instruction to install over top of the existing so we can correct that as I could not find it? I don't think that is correct and definitely bad practice as it causes problems with install counts in the registry. With MSI installed applications always uninstall the old first then the new.
    Best Regards,
    Shaan
    Shaan Hurley
    Autodesk, Inc.
    ExistingConditions
    02-16-2011 07:56 AM in reply to: ExistingConditions
    Here is the article that says to install over the previous version.
    http://labs.blogs.com/its_alive_in_the_lab/2011/02/shape-extraction-for-autocad-extended-to-august-1...
    I had to download windows install clean up to remove the original version and then the new msi file worked file to install.
    Employee
    02-16-2011 08:20 AM in reply to: ExistingConditions
    Thank you. I will talk weith the team as installing over a MSI is not advised but perhaps there is something special in this MSI installer. Glad the instal remover solved your issue.
    -Shaan
    Shaan Hurley
    Autodesk, Inc.
    Board Manager
    02-16-2011 09:10 AM in reply to: shaan.hurley
    In this other thread:
    http://forums.autodesk.com/t5/Shape-Extraction-for-AutoCAD/Shape-Extraction-for-Autocad/td-p/2895824
    travistlo only had success by installing the new version over the older one.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
