I'm trying to generate a lightmap from the command line using Mental Ray. If I render from inside Maya the "Mental Ray Baking Options" have a "Fill Texture Seams" setting.
When I run the command line: Render -r lightmap all the settings are available except for 'Fill Texture Seams"
Is there a way to set this value from the command line?
Thanks!
I figured out how to enable this command line parameter, on mac:
Edit Maya.app/Contents/bin/rendererDesc/lightmapRenderer.xml and add:
<attr n="fillTextureSeams" p="1" s='($tmpSet + ".fillTextureSeams")' t="float" h="Set the Fill Texture Seams"/>
after this node:
<attr n="vMax" p="1" s='($tmpSet + ".vMax")' t="float" h="Max V value for lightmap. Used if uvRange is set to User Specified."/>
No the parameter will be taken into account on the command line.
