2015 design now tells me:
MSG 0.0 10 MB error: Atmospheric "Hair Atmospheric" is not supported.
It still renders but somehow look like it has changed, especially in the viewport hairs look shorter.
hi, It just warn your some function of H&F are not "supported" by mental ray.
I never received this warning in 2014, it ony happens in 2015.
So are you telling me Mental Ray no longer supports hair and fur?
Your reply just kindof repeated my first post and did not explain anything.
hair and fur does render but since 2015 version it looks terrible and throws error message.
could anybody explain what the deal is with hair and fur used in conjuncyion with Mental Ray renderer.
Not exactly sure what you mean.
I have my hair n fur set to mrPrims. Everything was fine in 2014, but in 2015 viewport hair looks wrong, rendering with MR gives the error but also renders the hair, albeit not looking the same as in 2014.
What i mean is some functions mabye don't work in mental ray, but I am not sure what it is.
Could you send me a simple scene file - 2014 version? I will check what different between 2014 and 2015. Thank!
Today I opened the 2014 file and it now appears to have the same problems as the 2015 version (looks wrong in viewport and renders looking wrong plus error).
Has something happened to my 2014 installation since I installed 2015?
Since 2015 installation, it seems to have changed my 2014 files (in terms of hair n fur)
I'm not sure. We must test on differen versions to see if it is regression.
But you know, VP2 is a kind of hardware renderer - using GPU and mental ray is a software renderer - using CPU. The resoult of those renderer can be very close, but couldn't be same.
We update VP2 every year to improve it, and we can see it is better in every new version.
So where does this leave me with my current problem?
I was in the middle of a project using hair n fur, along comes 3ds max 2015 and......
My proj is stuffed?
No matter how I explain it, I am wasting my time?
So, Max 2015 Mental Ray no longer supports buffer hairs? All buffer parameters grayed out and its renders fully like "geometry" hairs (by rendered image and render times), no HairAndFur modifier material parameters is considered. And I cannot find any information about that in Max help...
Max 2015 with extension2.
Thank you autodesk, now I must redo my character scene from Max 2014... *facepalm*
