My rendering, shown below, keeps wrapping the image that I'm using for the Environment Map, creating a vortex-like appearance as the background. I attempted to change this characteristic in the material window to "Screen" instead of "Spherical Object", but that has not changed anything. Does anyone know how I could change this? Any help would be very much appreciated. Thank you.
P.S. I'm new to the forum and I could not find any topic on this particular "issue", so sorry if this is a repeat.
Solved by PROH. Go to Solution.
Does no one know how to fix this issue? That would surprise me.
Again, any help would be very much appreciated. Thank you.
Several questions: How did you setup the Environment Map? Was it via Environment dialog, or is it a Spherical object? Are you displaying the map in your viewport? Could you do a screen grab of showing the Viewport, Envrionment dialog, and Material Editor?
Thank you for replying. I have attached the Environment Map with the Material Editor as well as the viewport. Could the initial daylight settings be the reason this is happening?
Great catch, it worked! Thank you very much assisting me; both of you, I really appreciate it.
I thought that I had done that before when I first had trouble with this a few months ago, but I guess there were other hidden issues that were eventually solved for that to finally work. Again, thank you for the help!
Glad you solved the problem. 🙂
