Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Switching MR to MayaSoftwareRenderer changes the openexr output format to iff
1 REPLY 1
willanie
264 Views, 1 Reply
When ever I switch between Mentalray and Mayasoftware the openexr output format setting is permanently switched to iff. I understand that Mayasoftware does not support openexr but this makes it impossible to mix renderers in one maya scene and still output openexr. How do I prevent this? This is the case in Maya2014 as well as previous Maya versions.
1 REPLY 1
rahulrohilla
in reply to: willanie
Whenever you are switching to Mr to software for a particular layer , Right click on "Render using" and change it to Software. then layer override the Image format option to whatever you required .
It Should work .
