Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Silly rendering question--ditching the depth files?
18 REPLIES 18
Message 1 of 19
whisper1
917 Views, 18 Replies
For some reason, when I'm batch rendering, sometimes I get a bunch of "_depth" files. Usually, I don't, but when I do, it means manually selecting and deleting them. I can never remember which setting it is that gets rid of them. Which tick-box is it?
18 REPLIES 18
Message 2 of 19
n8skow
in reply to: whisper1
Is 'Depth channel (Z depth) unchecked in your Render Settings?
Message 3 of 19
whisper1
in reply to: n8skow
I have tried it checked.
I have tried it unchecked.
Both ways I ended up with "depth" files.
Message 4 of 19
whisper1
in reply to: n8skow
Thanks, but either checked or unchecked, the problem remains.
Suggestions?
Message 5 of 19
n8skow
Are you initiating your renders from the Batch Renderer or another way?
Message 6 of 19
whisper1
in reply to: n8skow
Batch Render, using Maya Software. This isn't the first time this has come up, but it is the first time I haven't been able to figure out how to make it go away.
Message 7 of 19
whisper1
OK, now I'm mad. I just finished a project last week with over 16000 frames where I had to MANUALLY delete all these friggin depth files.
This week, I started a whole new project.
I started some test renders last night, and everything was fine.
Now, this morning, after I had to restart the program, I once again have these obnoxious friggin depth files. I did not make ANY changes to the render settings. I did not make any changes to the geometry (aside from adjusting X, Y, & Z positions) or materials, or lights, or camera, or anything else.
What causes them?
More importantly HOW THE HELL DO I GET RID OF THEM.
Sorry. As I said, I am getting extremely angry and frustrated.
Message 8 of 19
n8skow
Have you tried rebuilding your Maya preferences file?
Sounds like there is a hiccup somewhere...
Message 9 of 19
whisper1
in reply to: n8skow
Um, how would I go about doing that? Working on a completely different project now, and everything was fine, until last week, when the depth files started showing up again.
Message 10 of 19
n8skow
Simply delete or backup your exisiting Maya preferences to a different location, and restart Maya (it will recreate the preferences when you start it up again).
Are you on Mac or PC?
Message 11 of 19
whisper1
in reply to: n8skow
Uh huh. and where to I find "Delete Preferences"? I have shut down and restarted Maya and the computer several times since I started complaining about this.
PC.
Message 12 of 19
n8skow
On Pc it will be in \Users\username\My Documents\maya\version\prefs
Either rename or remove from this directory your userprefs.mel file, and then restart Maya to rebuild it.
Message 13 of 19
whisper1
in reply to: n8skow
Once again, I'm stuck with these stupid Depth files.
Started from scratch on a brand new project.
This should be really simple.
Normally, when I watch the render folder the project is set to, the _depth files appear while the frame is in progress, then disappear when the frame finishes and the next starts.
What is the setting that makes these things go away?
Why would anyone want them in the first place?
Message 14 of 19
whisper1
And no, deleting the perf did not solve the problem.
Sorry.
Message 15 of 19
whisper1
I'm guessing that this problem is just part of the "Black Arts" of Maya, and no one knows what setting will solve the problem?
Message 16 of 19
n8skow
I'm not sure I follow what's going on at this point...
The depth files appear then disappear?
Message 17 of 19
whisper1
in reply to: n8skow
When the system works properly, yes. Then it is no problem.
Sadly, they show up and stay there. I have to manually select and delete them. Constantly.
Message 18 of 19
whisper1
Somehow, getting Mayatomr back on has solved this problem. Is there some relation? Hell if I know. I just know that the problem seems to have been solved.
Thank you all.
Message 19 of 19
zanefx
I am having the same problem. I am submitting maya softare render from a script using command-line Render. Can you be more specific about how you solved this? Did you simply load "Mayatomr" plugin?? I tried that and I'm still getting unwanted depth renders.
Thanks for any suggestions,
Suzanne
