Solved by samab. Go to Solution.
There is nothing to stop you from rendering from the Perspective view, it works perfectly well. But it doesn't hurt to add a camera, it may be useful to you. For example, if you want to do any further work on the scene, it may be difficult to get back to the exact same view after moving the perspective view.
You can use View - Create Camera From View (Ctrl+C) to make a camera that exactly matches your current view.
