Hi guys, My rendering looks prefect on the outside of the building:
but on the inside it gets too bright:
here are my 3ds max settings:
Hope you guys could help me
Thanks in advance 🙂
Solved by darawork. Go to Solution.
Could you save your project out of Max as an Archive (.zip) and upload it here?
Or if you don't want to make it publically shared, just message me a dropbox link to the .zip or maybe use sendspace.com?
File -> Save as -> Archive.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
I found out that the Architectural opacity material used on the floor was not working as expected and was filling the room with light. I changed the material type to an Arch & Design material with the same difuse and cutout (opacity) bitmaps and it is now working correctly.
Darawork
AutoDesk User
