We've been having a problem for a while where Studio Max locks the renderable viewport so that no matter which view you have selected it always renders the same view. Once this happens there is no way to change which view renders other than restarting the program. And no this isn't because I have the camera locked in the render scene dialog! It's incredible frustrating and I've had no luck resolving it. Has anyone come across this before and know why it might happen? We're using 2014 and Vray 2, although we experience the same issue in 2012.
Cheers
Nick
Solved by AlexRichards. Go to Solution.
How are you triggering the render - using the Render button on the F9 key?
With the F9 key. Pretty sure it doesn't make a difference though. We all generally use the Vray Frame Buffer as well but again I'm pretty sure once it's locked it doesn't matter whether you're using the Max Frame Buffer or the Vray one.
Nick
Ah, I think F9 is actually 'render last', so it will render the last viewport that was rendered, even if a different viewport is selected. If you use the Render button on the Render Options panel, it should render using current active viewport.
I wish it was so simple. As it hasn't happened today I can't 100% confirm that pressing render doesn't do anything but I'm certain it makes no difference as I will have tried this in the past, along with changing the layout and maximising the view I want. I just completely lose the ability to decide which view to render.
Nick
If it does turn out to be the cause, you can reassign the F9 key from 'Render Last' to 'Render Production' in the Customise User Interface options. I know how handy the F9 shortcut is.
Alex
I had this problem today actually. I saved a render preset with the render locked to a camera in the source scene. When I loaded the preset in the new scene, there was no camera present. So it seemed to lock to the perspective or ortho views and I couldn't change the render view to any other view, no matter what I did.
To fix it, I returned to the scene I saved the render preset in and unlocked the camera in the render panel and resaved the preset. I had no problems afterwards, when I loaded this new preset in any new scene.
Alex
Hi i had this trouble too. But i solved!! I don´t know why but te problem is that the viewport locks at the rendering frame window. Yo have to go to rendering->rendered frame window. There is a little padlock at the right of view port (in this selection is the anoying perspective). Only Unlock the padlock and try again rendering the selected view.
Many thanks for the tip, Edgar! It indeed works.
Interesting is, playing with the padlock (i suppose it has the same function) in Render Setup window doesnt solve this...
thanks that did the trick (first i was looking for this button to lock it to my camera... then i was trying to get rid of it as it locked it to my perspective cam and drove me nuts for 20 mins... didn't look into the default rendered frame window as i was using vray rt)
thank 🙂
m.
I had the same problem
HERE IS A FIX that worked for me:
Just change renderer to Scanline
Click Render
Change renderer back to Vray
