3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Remove saved render presets
2 REPLIES 2
3103 Views, 2 Replies
Hello everyone,
I have created several render presets in 3ds Max and they are now stored at the bottom drop down menu (beside the Render button in Render Setup).
How do I remove render presets? I've accumulated too many duplicates without realizing 3ds Max will keep every single preset saved in this list.
I want to trim the saved / stored presets in this list.
Please help.
Thank you.
2 REPLIES 2
darawork
This is where mine are located:
"C:\Program Files\Autodesk\3ds Max Design 2014\renderpresets"
Each one has an .rps file
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Kingosfer
hi,
Do this, open 3d max, F10, select the preset you want destroy (PresetA) and load it. Then select another one (PresetB), whichever and load it to. After eliminate the .rps archive of the folder where this "PresetA" is, and then go back to 3d max, and try to reload this eliminated rps. 3Dmax will remove it automaticaly.
