Hi! I'm begginer in Maya, so please be patient . I have problem with physical sun and sky and also with imaged based lighting. In render view everythnig is ok, but when I batch render or save image on the place where should be physical sky is alpha, or if i uncheck "Alpha Channel (Mask)" in render settings black color appears. I tried to render in iff, rla and png format. I just don't want this alpha channel on my renders, but i want to render my animation in .rla format with z-depth. Please help. Yours Sincerely Rookie3.
:)) which composit program will you use?
if you use After effects when you import it, it will give you some options, if you choose ignore you wont see as black... or alpha...
check the pics i added..
another solution if you want render out without alpha from maya, in file type choose .jpeg
