I've a problem with the minimised display tab of my 'Indirect Lighting' tab as shown in the above 1st image. The 'Quality' tab, however, and the other tabs are fine.
I could not scroll and read the options in the 'Indirect Lighting' tab, can someone help me with this issue?
Did you find a solution to this problem? I might start with unloading/reloading the mental ray plug-in; if that doesn't work, exit Maya, delete (or rename) your userPrefs.mel file, and re-start Maya. I don't think I"ve ever seen this one before.
