Maya 2015 student version crashes when using mila material on an object and then trying to open the UV editor for this object. Anybody knows the problem?
Best Regards,
Josef
Solved by steve_r. Go to Solution.
There was a known issue if you start with a "diffuse (scatter)" layer and open Maya UV Editor (crash with "access null DB tag"). It is supposed to be fixed with the latest MILA package which should appear in a next Maya SP.
Okay thank you steve, yes, I forgot to mention that it happen with the scatter layer! Nice to hear that there is a solution!
