I have a simple objects with different textures on each side. How can I combine all textures into 1 so that the object has only 1 texture onto it ?
Thanks.
Solved by _sebastian_f. Go to Solution.
OK, here is a screen shot. I applied here simple lambert colors (in reality each color is a different file texture).
How to combine these in 1 uv
Thanks !
Clear, thanks. That what I was afraid of, because my real object has this shape but is smoothed, and therefore has a lot of small polygons which makes it unviewable in the exported file (because of the too narrow grid.
