Hi there, I've just begun studies on autodesk maya. About half a year in now. But I just can't seem to get a perfect quality playblast, I also hear batch render is also an option. Please leave which you prefer and how you would set it up.
Not sure what you mean by 'perfect quality'...
What is it you are trying to do exactly?
Playblasts are generally low-rez/low-quality for speed reasons...
Playblast just screencaptures your animation from the viewport - typically used to checked the the timing and composition of an animation. It sounds like you are wanting to do an actual render - which you could initatiate from the batch renderer...
http://help.autodesk.com/view/MAYAUL/2015/ENU/?guid=GUID-8A51B291-706A-434F-B97D-A3720A525E24
Hi
If want to to a batch render there is the path
Check the image you will be able to do batch render.
