sorry, I attached a zipped folder now.... with the .max files. I also zipped a 2011 version, because I use 3ds max 2014.
Biggest mistake in your file is wrong scale. Whole scene is 10 times smaller than it should be. It is very bad. You should always work with correct scale.
I played a bit with your scene. Added couple more portals, changed skylight mode from ibl to fg, upped fg preset from draft to low, tweaked a little bit photon mapping settings, adjusted exposure, tweaked sun's photon targeting, turned off omni light and changed shadow maps to raytraced shadows. Your interrior lights are very dim you should brighten it. Scene materials are all wrong, so i just replaced them with simple grey mat.
I will attach max scene later.
thanks a lot for your help romullus!! I am aware of the scale problem... thought it wouldn't matter so much, but appearently it does....so I will keep this in mind:)
Do you know why I can't add materials to the scene? I tried to give the floor a pink color, just to see if anything changes, but if I render the scene everythings stays grey... although I can see the pink color in my shaded perspective view...
It's because of material override. You should uncheck it. It's in processing tab.
