Hi Guys! I desperately need help !!
I'm working on a scene from 3 months and now i have to render it trough batch render, i need to split the various part that compose the scene, so i used a set of contribution maps,but i ' ve encountered a series of problems that, i'm not sure it's all about using contribtion maps, are driving me crazy.
First : rendering in window do not generate correct passes or take account of the contribution map, that means: wacthing in the viewer after the rendering the passes looks all the same .
Second: when batch rendering the progress for the first frame stops at 25 % and get stuck there everytime.
Third : i ran a diagnostic tool and decided to convert all my textures in map format to speed up the render, to delete unused nodes and clean up scene after that the batch render doesn't render at all and in the prompt window the only thing it shows are strange job name referring to memory debugging that progressively increase occupied memory without starting the actual render
i have 32 gb of memory , and run maya batch from prompt. i have no idea how to resolve this problem
I thought it was the scene size or the texture size but all my texture occupies about 500 Mb .
Please help me cause i worked so much on this and i don't want to lose everything !
Thank you very much !!
