Hello friends,
I have been working on some concepts for a product at work, but every render I make for everything I do, the anti-aliasing is too much, changing settings in Render Globals doesn't do much. Every tutorial has not fixed anything for me.
At first I thought it was problems in the Render Globals, until I exported the image as a jpeg, and now the lines are smooth.
Attached is the Render View, how can I evaluate my renders if I can't see them properly in my Render View?
Solved by Can-3DCG. Go to Solution.
you zoomed the picture down to 0.757.
In render view select in the menu View/Realszie or just right click and select View/Realsize.
That zoomes back to 1.00 and the crappy egdes will look smooth again.
Down zooming interpolates not fine in Maya Renderview.
Cheers,
Can
