I'm currently working on a project with a lot of .swf assets, and I have a problem when building on Android.
As you might know, the maximum allowed size for an apk to be uploaded on google play is 50 mb. So you have to split your application into an apk < 50 mb and several .obb files that contains the data.
Unity has a feature that do that automatically.
The problem is that the content of the StreamingAssets/ folder is moved in the .obb and that scaleform can't access it, because the path seems to be hardcoded in the .dll, and we can't find a way to tell Scaleform where to look.
Am I missing something? Is Anybody having the same problem?
This seems unlikely that Autodesk has not think of this possibility...
This is kind of urgent, we need to release this application really soon.
This issue has been posted before. See this discussion.
Basically, I had to resort to independent SWFs, no external files, no GFX conversion, etc. Scaleform hasn't fixed this issue yet.
Hope this helps,
-K
Did this get addressed in the July update? We're running into the same issue. Did anyone find a fix?
Loading from an OBB is not fixed, yet.
It has been partially addressed in the latest update. That is, if you extract the OBBs to a path, you can instruct SF Unity to load resources relative to that path. There's a movieName parameter passed to CreationParams for this purpose. See use of Util.cs, CreateSwf. The last parameter is the movieName, which should be the full path to the swf/gfx you're loading.
Unfortunately, I do not have an estimate when the OBB issue can be properly addressed.
Adam
Cool, Adam, thank you -- it looks like there's a workaround then anyway.
If I could ask a followup question:
I'm reducing memory by loading large graphics in and out manually. I have these sitting in the Streaming Assets folder and this works fantastic on both Android and iOS. Will this conflict at all with the OBB situation?
Thanks again!
This depends on two factors:
1) On Unity and where it draws the line at splitting the APK and OBB. From experience, Unity tries attempts dependency heuristics based on its own assets and what you need to load the first scene.
2) How you're loading the graphics.
If you're using Unity to load the images, you're fine. It handles the APK/OBB divide seamlessly.
If you're loading a swf/gfx which, in turn, loads one of those graphics, it will likely fail unless you use the workaround I mentioned above.
I hope that helps,
Adam
I'd like to second the urgency for fixing AS3 loading from an obb file.
Our OBB is in excess of 200MB so not practical to extract out the contents.
