Hi Joey-
Thanks for trying out the Scaleform-Unity Integration. It appears that your error is due to the dll not being able to load.
Here's what you can do to solve this issue:
Some of you might get a “dllnotfound” exception while running the HelloWorldDemo.
We have identified that this exception is caused due to a missing dll that is on the dependency list of libgfxunity.dll. You can use the following tool:
http://www.ntcore.com/exsuite.phpto view the dependency tree of our dll.
If you get the “dll not found” exception, it is likely that d3dx9_43.dll is missing on the target computer, which is causing the main integration dll to not load.
You should be able to rectify this problem by just downloading the latest DirectX runtime.
Please let us know if this solves your problem.
Thanks!
Ankur
