The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Scaleform Forum (Read Only)
Scaleform enables developers to leverage the power of the Adobe® Flash® tool set to create powerful user interface environments for video games.
make / Makefile not working on Mavericks with Xcode 5.0.2
8 REPLIES 8
Message 1 of 9
gummudu
1717 Views, 8 Replies
I was going through the Getting Started PDF and trying to look at the StarforceTD project and run it on a device. For that to be available I have to run make in the scaleform root against the Makefile present there with make P=iPhone/armv7 C=Release+NoRTTI but this results in this error:
  cc     Src/Sound/Sound_SoundRenderer.cpp
make: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/gcc: No such file or directory
make: *** [Obj/iPhone-armv7/Release_NoRTTI/Src/Sound/Sound_SoundRenderer.o] Error 1
I think it is because gcc is no longer located under iPhoneOS.platform/Developer/usr/bin with XCode 5.
Any change to get an updated Makefile or some instructions on how to get this working with XCode 5 on Mavericks? Would be really appreciated 🙂
Thanks!
8 REPLIES 8
Message 2 of 9
gummudu
in reply to: gummudu
using scaleform_4.2.24_iphone_consumer btw
Message 3 of 9
adam.petrone
Hello gummudu,
For Xcode 5, specify clang in the command line:
make P=iPhone+clang/armv7 C=Release+NoRTTI
Message 4 of 9
gummudu
in reply to: adam.petrone
That worked! 😄 thanks a million
Message 5 of 9
legosarecool
I also ran into this issue, but it doesn't fully fix the build pipeline.  I get this error when building curl:
checking for stdint.h... (cached) no
checking for unistd.h... no
checking size of long... 0
checking size of void*... 0
configure: error: cannot find out size of long.
make: *** [Obj/iPhone-armv7-clang/3rdParty/curl-7.29.0/libcurl.a] Error 1
Is there a similar fix for this issue as well?
Message 6 of 9
adam.petrone
in reply to: legosarecool
Hello legosarecool,
Which package are you using? libcurl is not in scaleform_4.2.24_iphone_consumer.
Adam
Message 7 of 9
legosarecool
I'm using the sf_4.3.26_ios_armv7_eval package.
Message 8 of 9
adam.petrone
legosarecool,
You can try this. Our build engineer may have a more elegant fix, but in the meantime - you will need to modify the shell script at 3rdParty/curl-7.29.0/SFcurlHelper.sh
Around line 58, look for these lines:
export CC=${IOS_CC}
export CPP=${IOS_CPP}
Replace the CFLAGS and LDFLAGS with this (this resolves the headers not being found):
export CFLAGS="-arch ${IOS_ARCH} -isysroot ${IPHONEVER} ${COMMON_CFLAGS}"
export LDFLAGS="-Wl,-syslibroot ${IPHONEVER}"
And add this line (this resolves three errors on 10.9 with clang):
export CPPFLAGS="-D_FORTIFY_SOURCE=0"
Message 9 of 9
legosarecool
Thanks Adam, that fixed it!
