Just came across Scaleform and thinks its a great idea and exactly what I was looking for. I am trying out product out using the eval key but I cant seem to get the default Starforce apk to build and load onto my Android device.
My main issue is with the keystore and java:
jarsigner -keystore C:/cygwin64/home/Hiren/.android/debug.keystore -storepass android LocalApps/StarforceTD/Android/StarforceTD.apk.unaligned androiddebugkey jarsigner error: java.lang.RuntimeException: keystore load: Keystore was tampered with, or password was incorrect Projects/Common/ShippingPlayer.mk:82: recipe for target 'LocalApps/StarforceTD/Android/StarforceTD.apk' failed make: *** [LocalApps/StarforceTD/Android/StarforceTD.apk] Error 1
This is from the Deployer app but I get similar when run through cygwin command. My main concern is the line "-storepass android". 'android' is NOT the password for the keystore I generated in java keytools. I have struggled all day with this but Im hoping I can get this to work as it will be one of our most useful tools.
I have tried both jdk 1.6 and 1.7. cygwin64 is the latest at this time. scaleform is 4.2. Android sdk is v19.
I am working on a Windows 7 64bit OS.
Let me know if you need more info from me.
hp
UPDATE:
I got passed this stage but now I have the following error:
jarsigner: Certificate chain not found for: androiddebugkey. androiddebugkey must reference a valid KeyStore key entry containing a private key and corresponding public key certificate chain.
Is there a step by step process to generate the relavent .keystore and certificate which would work on scaleform?
The Android developer site doesnt really help. For example, scaleform uses the default password 'android' but doesnt specify that anywhere. I want to have instructions which would work with scaleform guaranteed.
How did you set your cygwin to sign it with your own keystore and not debug.keystore.?
So that if you build it, it will be ready for upload on google play
