We are using SDK 4.2.24 for iOS and using SharedObject.getLocal("filename") and flush() to save it. When we then try to load the save file again it does not find it. I opened up Xcode Organizer and exported the data on the phone. It shows that the file "null_filename.sox" was created. Has anyone else used SharedObjects on iOS successfully?
Just fixed this issue. SharedObject.getLocal was saving and loading the sox fileproperly. Since we were saving JSON, it would cause the XML parser in FxSharedObjectManager to crap out. I saved the data in base64 and now everything parses fine. I also fixed the "null_filename" issue by just calling SharedObject.getLocal("filename", "").
