The flash extansions for CC can't be installed on MAC machine. It's because paths in the Scaleform Extensions.mxi file are using backward slashes "\" instead of forward one "/".
Changing the paths and zipping the extansion folder make it work.
Piotr
After installation it sitll doesn't work as during the player configuration (from extension panel) it doesn't accept the .app extension.
My work around was to manually change the path in the prefs.plist.
When the path for the player is correct it still doesn't work as the launcher just passes app path and the swf path to the command line.
Like cmd:"~/FxMediaPlayer.app flash.swf" - and this line of code does nothing.
You have to moddify the runCommandLine from:
FLfile.runCommandLine('/'+playerPath+" "+ p_commands.split("%SWF_PATH%").join('"'+winPath+'" '));
to:
FLfile.runCommandLine('open /'+playerPath+" --args "+ p_commands.split("%SWF_PATH%").join('"'+winPath+'" '));
And now it finally works.
Piotr
Hello piotrO82,
Thank you for the hard work in getting to the bottom of this and finding a solution!
Adam
