You can send a reinforcement of the slab in revit model that is generated automatically?
Solved by Artur.Kosakowski. Go to Solution.
If you mean to export reinforcement distribution generated in Robot for selected panels (slabs) to Revit then this is not possible. On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model.
