Just after clicking the open icon in the Section Properties dialog box, I get an unhandled exception. I have the latest service pack and hot fixes as referenced in another post. HEre is the error info:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.EntryPointNotFoundException: Unable to find an entry point named 'SYS_GetLangAbbr' in DLL 'conf.dll'.
at DRobotSectLblMngr.frmSectionLabelManager.SYS_GetLangAbbr(Int16& lang)
at DRobotSectLblMngr.frmSectionLabelManager.Init()
at DRobotSectLblMngr.Main.MainOnTimer()
at DRobotSectLblMngr.frmTimer.Timer1_Tick(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
RobwinInterop
Assembly Version: 0.0.0.0
Win32 Version: 25,0,0,3774
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinInterop.DLL
msvcm90
Assembly Version: 9.0.30729.4940
Win32 Version: 9.00.30729.4940
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c/msvcm90.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
AdWindows
Assembly Version: 3.2.25.0
Win32 Version: 3.2.25.0
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdWindows.DLL
PresentationCore
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5442 built by: Win7SP1GDR
CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationFramework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdApplicationFrame.DLL
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
RobwinRibbon
Assembly Version: 1.0.0.0
Win32 Version: 25.0.0.3774
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinRibbon.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Autodesk.Common.DOptionSetOrganizer
Assembly Version: 23.0.0.0
Win32 Version: 25.0.0.3756
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/Autodesk.Common.DOptionSetOrganizer.dll
Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.Common.DOptionSetOrganizer.Resources
Win32 Version: 23.0.0.0
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/en-US/Autodesk.Common.DOptionSetOrganizer.resources.DLL
Autodesk.Common.DTabControlSelector
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/Autodesk.Common.DTabControlSelector.dll
Autodesk.Common.DTabControlSelector.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/en-US/Autodesk.Common.DTabControlSelector.resources.DLL
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Autodesk.REX.Loader
Win32 Version: 2012.0.0.1769
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Loader/Autodesk.REX.Loader.dll
Autodesk.REX.Framework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.REX.Framework/1.0.0.0__51e16e3b26b42eda/Autodesk.REX.Framework.dll
Autodesk.Common.AResourcesControl
Win32 Version: 2012.0.0.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Common.AResourcesControl/1.0.0.0__ff3304d4f320ee59/Autodesk.Common.AResourcesControl.dll
AREXRobotMngr
Assembly Version: 2012.0.0.1161
Win32 Version: 2012.0.0.1161
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Products/Robot/AREXRobotMngr.dll
Interop.RobotOM
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.RobotOM.DLL
REX.Manager
Assembly Version: 2012.0.0.1769
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Manager.dll
REX.Engine
Assembly Version: 2012.0.0.1422
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Engine.dll
REX.Preferences
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Preferences.DLL
REX.System
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.System.DLL
REX.UI.WPF
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.WPF.DLL
REX.UI
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.DLL
REX.UI.Forms
Assembly Version: 2012.0.0.1642
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.Forms.DLL
REX.UI.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.UI.resources.DLL
REX.Foundation
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Foundation/REX.Foundation.dll
REX.System.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.System.resources.dll
REX.Manager.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.Manager.resources.dll
DRobotSectLblMngr
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/DRobotSectLblMngr.DLL
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
DRobotSectLblMngr.Resources
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/en-US/DRobotSectLblMngr.resources.DLL
Interop.syspathsLib
Assembly Version: 5.0.0.0
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.syspathsLib.DLL
Interop.IDbRootLib
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.IDbRootLib.DLL
Microsoft.VisualBasic.Compatibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Solved by Artur.Kosakowski. Go to Solution.
Try to delete files from Windows TEMP dialog and rename your CfgUsr folder.
Cfgusr
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win 7 32- or 64-bit RSAPro:
Has this solved this problem?
when you say "temp dialog" do you mean here for windows 7?:
C:\Windows\Temp
or here?:
C:\Users\mbrule\AppData\Local\Temp
In case this doesn't help make screen capture and indicate the icon you press as well as include the viewer opened when you use Help > Robot information commands being in any model with the structure in Robot.
I tried your suggestion but got the same exact error. I get it when clicking open in the Sections dialog box (the dialog you get when clicking the icon that looks like a red capital letter i). Curiously, I got a popup about an available autodesk update so I click it and it began downloading service pack 5. I was puzzled because I made sure when I created the deploy for this that the latest updates would be included in the deploy. However, there is a download button under the service pack 5 to include and it began showing a green progress bar while it downloads. I thought it would have done this in thd background as it creates the deploy but maybe not. It's possible then that the end user having this issue also doesn't have SP5 for RSA 2012 so I will allow this to fully download and test again on my test box. If it corrects the issue, then chalk it up to lack of an important update. I'll keep you posted.
If this is your situation:
then it has been corrected in HF3 for Robot 2012.
the image is a bit too small to see details but installing SP5 resolved that error. i am waiting for the end user who has this problem to try it and get back to me.
Yup, that's the button generating the error. So far so good after installing SP 5 but I am still waiting to hear back from the end user that it is actually working for him now.
I looked around for HF3 but could only locate HF2. Can you post a link for me? Thanks!
