Discussion Groups
Robot Structural Analysis
Valued Contributor
CKDDIZ
truss design
1385 Views, 17 Replies
08-27-2012 06:19 AM
hello,
my question is related to truss design,when the moment release is applied to the truss member during calculations the instability window appears!!! Why does this happen?
Please use plain text.
Rafacascudo
Re: truss design
08-27-2012 06:32 AM in reply to: CKDDIZ
You shouldn´t apply releases to the members that have a pinned support as one of their nodes.
Also ,Instead of using releases you can use "truss bars  only" through geometry/additonal atributes/advanced properties
Valued Contributor
CKDDIZ
Re: truss design
08-27-2012 07:24 AM in reply to: Rafacascudo
I tryed to model an example from the truss database selection on two fixed columns, the truss members are moment realesed from the truss table option.
Still got the stability window during calcs!!
Product Support
Artur.Kosakowski
Re: truss design
08-27-2012 07:40 AM in reply to: CKDDIZ
Delete the side posts and replace them with the columns.
Artur Kosakowski
Valued Contributor
CKDDIZ
Re: truss design
01-08-2013 01:22 AM in reply to: Artur.Kosakowski
calculated a truss in 2D in truss structure type (pic 1), exporting it in 3D ( pic 2) getting instability in Y dir.
Suggestions please!
Thank you
Product Support
Artur.Kosakowski
Re: truss design
01-08-2013 01:54 AM in reply to: CKDDIZ
If you have out of truss plane releases nothing prevent horizontal movement of its elements in this direction. I think you should add some boundary conditions (or redefine the releases) to prevent this from happening.
Artur Kosakowski
Valued Contributor
CKDDIZ
Re: truss design
01-08-2013 04:57 AM in reply to: Artur.Kosakowski
1) using the truss bar option without any bar release, getting the same instability type.
2) using bar release in X,Z direction only , same instability.
Trying to solve the roof structure in 3D, how important is the bar offset of the transversal beams (purlins) in this case?
Do you recommend roof as cladding, and wind load applied on it?
Product Support
Artur.Kosakowski
Re: truss design
01-08-2013 05:11 AM in reply to: CKDDIZ
Truss bars are similar to bars with pinned end connections.
For a 3D structural roof you should keep the chords as continuous (see the attached model). Otherwise you can consider use of partial releases.
 Personally I would not define any offsets.
This is one of the options but this is going to be your decision :smileyhappy:
P.S. I have corrected the error of not applying truss bar attribute to one line of posts in the attached model too.
Artur Kosakowski
Valued Contributor
CKDDIZ
Re: truss design
01-08-2013 05:47 AM in reply to: Artur.Kosakowski
Thanks :smileywink:
Valued Contributor
CKDDIZ
Re: truss design
01-08-2013 06:05 AM in reply to: CKDDIZ
Is there an option in RSA, example 2 bars to be connected as 1?
