Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
time history analysis
31 REPLIES 31
Message 1 of 32
845 Views, 31 Replies
Bonjour,
je veux faire une analyse temporelle d'une structure non lineaire (passerelle haubanée).
J'ai mon cas 1 poids propre, que j'ai transformé en masse
cas 2 analyse modale
cas 3 le cas de charge de piéton
cas 4 analyse temporelle, methode de Newmark, j'ai défini ma fonction et mon cas 3
je n'obtiens pas les bonnes valeurs d'accélération.
quand j'affiche les réactions, j'obtiens presque les memes valeurs dans le cas 1 et 3
est ce que le problème vient de là??
merci d'avance
31 REPLIES 31
Message 21 of 32
in reply to: Rafal.Gaweda
"As far as I undestood you \ we got very high accelerations in this model that's why we had to dense calculation steps to get maybe more accurate results.
UNfortunatelly such model did not converge."
if you read message #14, high accelerations are found in particular nodes, i don't know why!?
results in nodes 93, "seem" to be correct, but i didn't analyse long time enough.
Im doing it during 50s right now but calculations take a very long time!!!
I hope you are calculating it with Pdelta.
Yes I did!
concerning your setting: time step of 0.002s may be too long to calculate, don't you think?
Do we have any choice? This is the setting which MAY lead us to convergence. We will see.
perhaps!
I already did time history analysis with Robot on a simple linear model, and I found the expected results, but on a simple example I analyse during 300s, the acceleration becoming permanent after 50s. Calculations were not so long. Damping was the same: 0.004. And there was no particular elements.
Message 22 of 32
Rafal.Gaweda
Because it was linear model.
Rafal Gaweda
Message 23 of 32
hi,
I still try to do my THA,
i found something strange, i want to send you a file but it is 33Mb
in filemail they ask me for a emaiil address, how can i do?
Message 24 of 32
Rafal.Gaweda
send it to your address then post only the link here
Rafal Gaweda
Message 25 of 32
Ok,
https://www.filemail.com/dl.aspx?id=VXZFLAHGXSNFAIK
you will see, the analyse stop at step 548/1017
if you look at the mast at this step, he is buckling
what is weird: it has bending moment at foot, although it is a ball joint...
I don't understand!
Message 26 of 32
anyone have an idea?
I tried to divide the mast, and the buckling appears on new little element of the mast.
thanks
Message 27 of 32
Rafal.Gaweda
We got the same divergence...
Rafal Gaweda
Message 28 of 32
do you know the reason?
Message 29 of 32
also, at the very first step, the mast have bending moments in both direction at foot...!
Message 30 of 32
Rafal.Gaweda
You may see sometimes such effect in 1st step wht all loads are started to be apaplied
Results from step 2 till divergence are OK.
Rafal Gaweda
Message 31 of 32
why the divergence??
Message 32 of 32
Rafal.Gaweda
do not know yet. I guess it must be checked by developers.
Rafal Gaweda
