Hi.
I am trying to model a suspension bridge (attached) and simply cannot get the model to converge. I have tried changing the analysis parameters and cable definitions. Nothing so far has worked.
Could somebody give me a hint how to solve this problem.
Cheers,
Cornelia
This model is way too strange!!!
1- Bridge is on XY plane , gravity applied on -Y . Ok ,but not common
2- Main columms above deck level are UC 305x305x97 and are 150m long!!!
3- Transversal girders (UB305x165x40 and columms below deck have no material assigned
4- Main deck girders are rectangles of solid steel 4,72m x 1,00m !!!
I guess you have to correct lots of things before thinking about convergence!!
Rafael Medeiros
Hi.
Thanks for the quick reply.
The example is just a theoretical study of performance.
Depised all of the points you mentioned.
How does one get a nonlinear analysis to converge in robot.
I have never experienced this problem in Abqua.
