Hi, my pin supports are orientated in the z direction but should in my case be in the y direction. It shouldnt affect my model, however I didnt notice I needed to change my direction for the mass of the tunnel and was acting like a side node.
So in summary, can I change the orientation, its bugging me.
Also, how can one check the sum of all the forces in the model. for a solid element. The reactions table shows all the separate nodal reactions but not the total.
Regards
Solved by Artur.Kosakowski. Go to Solution.
Solved by HoshangMustafa. Go to Solution.
Hi
You change support definition. Please find attached file.
