how can i devided the slab into strip to get the moment on each strip ?
Solved by Artur.Kosakowski. Go to Solution.
This method is not used by Robot therefore you don't have the direct access to the results such as bending moment for a selected strip. Please check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Strange-results-in-moment-strip/td-p/4775885
http://forums.autodesk.com/t5/Robot-Structural-Analysis/mat-foundation/m-p/3714038
