hi guys,
I have a slab one-way structure, where the steel beam support the slab, but I think, I get a strange moment for the beams that shown in attached picture. I think the shown beams should have a bigger than the edge beam, but it looks on the contrary. I have also attached the model. Any help appreciated.
Your expectations are correct if you, for example, consider all beams of the same section (the same stiffeness)
in addtition to Rafal's comment, it is linked to the relative rigidity of the different element (pannels and bars).
See this model, load case 2, I change the rigidity of your slab to something like bubble gum -> tha slab behaves like cladding (that i put instead of pannels in the copied structure)
Actually in your model central bars is much less rigid than side bars -> the slab transfer some loads "from the middle" directly to the side beams as the central beam is quite flexible compared to the slab.
