I have a couple of questions regarding "story parameters" in designing rc column(see attached screenshot).
What does it mean of concrete age after erecting structure(the max value is 365 days, is this the case?Does it mean, that, it is the completion/construction of rc frame structure?)
.Creep coefficient - does the software automatically provides values based on existing concrete parameters?
Solved by saclovitzky. Go to Solution.
See the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
