I'm new in Robot, and want to know if it's possible to design connector by myself - in Robot or in ASD then import into Robot - (not costumize one of the software connections), then analyze/check it in Robot?
Solved by Artur.Kosakowski. Go to Solution.
In Robot you can only verify the predefined connection types as available from the list in the Steel Connection module.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Thanks for your answer. What about designing a new connector in ASD (=Autodesk....Detailing) then export it to Robot for checking/analyzing.
You cannot export connections from ASD to Robot. Such operation is not supported (available).
