Dear all
I have some question please help me to answer it
1. I do not fully understand how i can combine revit architectural and revit structural well in designing project
2. Using revit structural to design detail technical drawing in your lesson is awsome but autocad structural detailing also do it with the high quality.
Is it necessary to use revit structural for it? How can i combine them? if yes, when?
3. Designing BIM use firm sofware autodesk consist of: Revit architectural, revit structural, robot, autocad structural detailing. I wonder wether I think about it right or wrong?
Architectural model was completed in revit architectual, then link to revit structrual. Revit structrual will create structural model and move it to robot structural analysis to caculate
structural design elements then send result to revit structural, deploy detail in revit structural hay autocad structural detailing.
4. I know some structural design softwares:
-autodesk firm: Revit structure, Robot
- Graitec advance suite
- CSC Orion, Fastrak,S-frame
- Tekla
I hope you consult strengths and weaknesses of them? Besides I hope you can distinct Graitec và Robot?
5. That's greate if you can share with me some useful revit structural and autodesk robot documents? OK)
Sincerely, thank you so much!!!!!
THANKS ALL
Hi
I agree.
Please find the attached file.
thanks hi
please share to me a book to practice robot or revit structure
I saw file pdf of autodesk But It not good for fact
thanks
